alfredoolvera
file:///D:/documentos/canon%20partes/6560/6551/Partes/NP6250_6551pc.pdf
tecnycanon
336-1 copyright © 1997 canon inc. Canon np6350/6250/6251/6551 rev.1 dec. 1997 printed in japan [imprime au japon]
figure
key no.
part number
ra
nk
q’
t
y
description serial number / remarks
336 - fg5 - 8669 - 000 1 paper feed assembly see note 1,2
1 fa2 - 5606 - 000 1 drum, clutch driven
2 fa9 - 2112 - 000 2 bushing
3 fb2 - 7363 - 000 1 guide, paper
4 fb2 - 7364 - 000 1 guide, tray, fee
5 fb2 - 7365 - 000 1 shaft, paper delivery roller[[/i]/b][[/img]/u][/i]
6 fb2 - 7366 - 000 1 roller, registration
7 fb2 - 7376 - 000 1 guide, overlay
8 fb2 - 7377 - 000 1 roller, paper resistration
9 fb2 - 7380 - 000 1 spring, torsion
10 fb2 - 7415 - 000 1 link, overlay
11 fb2 - 7417 - 000 1 link
12 fb2 - 7458 - 020 1 ring, ratchet
13 fb2 - 7754 - 000 1 roller
14 fb2 - 7755 - 000 2 bushing
15 fb3 - 8598 - 000 1 shim
16 fc1 - 6195 - 000 1 damper
17 fc1 - 6196 - 000 1 damper
18 fc2 - 1175 - 000 2 screw
19 fc2 - 1532 - 000 2 roller, woodruff
20 ff5 - 2932 - 000 1 guide, left
21 ff5 - 2937 - 000 1 mount, reg. Paper sensing
22 ff5 - 2938 - 020 1 plate, weight
22a fb2 - 7413 - 020 2 shutter, weight
23 ff5 - 3142 - 000 1 guide, duplexing, left
23a fb2 - 7453 - 000 1 label, "left guide"
24 fg5 - 5040 - 000 1 cable, pick-up paper j762,763,7581
25 fh7 - 5400 - 000 1 solenoid, dc24v sl8 j759
26 fh7 - 5702 - 000 1 solenoid sl7 j760
27 fh7 - 7394 - 000 2 photo-interrupter ps14,17 j762,763
copyright © 1997 canon inc. Canon np6350/6250/6251/6551 rev.1 dec. 1997 printed in japan [imprime au japon] 336-2
figure
key no.
part number
ra
nk
q’
t
y
336 - 28 fs1 - 1119 - 000 2 bushing
29 fs1 - 1213 - 000 1 bushing
30 fs1 - 1213 - 000 1 bushing
31 fs2 - 0440 - 000 1 gear, 18t
32 fs2 - 0488 - 000 1 gear, 24t
33 fs2 - 0566 - 000 1 gear, 18t
34 fs2 - 2440 - 000 1 spring, clutch
35 fs3 - 2120 - 000 1 spring, tension
36 fs4 - 2047 - 000 1 spring, tension
37 fs5 - 1466 - 000 2 bushing
38 fs5 - 2929 - 000 2 spring, tension
39 fs5 - 2930 - 000 2 spring, tension
40 fs5 - 2931 - 000 2 spring, compression
41 fs5 - 2932 - 000 1 spring, tension
42 fs5 - 9218 - 000 1 screw,stepped,m3
43 fs5 - 9277 - 000 2 screw,rs stepped,m4
44 fs6 - 0091 - 000 2 gear, 16t
45 vs1 - 5057 - 002 2 connector, snap tight j759,760
46 vs1 - 5057 - 003 1 connector, snap tight j875
47 vs1 - 5057 - 006 1 connector, snap tight j7581
48 vs1 - 5057 - 013 1 connector, snap tight j758
49 wt2 - 5178 - 000 5 clip, cable
50 xa9 - 0628 - 000 11 screw,rs,m4x8
501 xb1 - 2300 - 409 2 screw,mach.,truss head,m3x4
502 xb1 - 2300 - 409 2 screw,mach.,truss head,m3x4
503 xb1 - 2300 - 609 2 screw,mach.,truss head,m3x6
504 xb1 - 2300 - 609 1 screw,mach.,truss head,m3x6
505 xb1 - 2300 - 609 2 screw,mach.,truss head,m3x6
506 xb1 - 2300 - 809 2 screw,mach.,truss head,m3x8
507 xb6 - 2400 - 508 1 setscrew,m4x5
336-3 copyright © 1997 canon inc. Canon np6350/6250/6251/6551 rev.1 dec. 1997 printed in japan [imprime au japon]
figure
key no.
part number
ra
nk
q’
t
y
336 - 508 xd2 - 1100 - 502 2 ring,e
509 xd2 - 1100 - 502 1 ring,e
510 xd2 - 1100 - 642 7 ring,e
511 xd2 - 2300 - 302 4 ring,toothed lock
512 xd3 - 1300 - 082 1 pin,spring
513 xd3 - 1300 - 102 1 pin,spring
514 xd3 - 2200 - 102 1 pin,dowel
515 xd3 - 2200 - 122 1 pin,dowel
516 xd3 - 2200 - 122 1 pin,dowel
517 xd3 - 2200 - 142 1 pin,dowel
copyright
tecnycanon
