Quisiera saber si alguien conociera estos errores "0030 y 0001", pudiera dar alguna información más específica o cierta.
Damisak
tesla6
Claro el equipo es trifasico 380V, el rango que debe estar entre 340V - 440V.
De fase a fase: 381V, 382V, 380V
De fase a neutro: 220V, 221V, 219V
Ademas de esto, cuando dejo el equipo conectado solo al empalme del recinto y consume energia practicamente solo sube a 390V.
Nose si el proble es de tierra, contaminacion de corriente o falta de banco de condensadores.
Damisak
tesla6
Damisak
Err030: Console HW . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27
Err030: Console HW 0
Description:
• An error in the console hardware has occurred.
Possible Causes of Error:
• 24 V power supply malfunctioning
• D501 connections X7 and X8 switched
• Console defective
• W515 or W500, W509, W510 cable defective or contact problems
• D501 defective.
Err001: No communication between control console and generator 0
Description:
• Control console could not establish a connection to the generator
• D300 processor (MCB2) or D500 not running.
• W515 console cable defective.
• D501 defective
Yamil
yamil7399
also throws a couple of times errors 0010 and 0034, you could see them please.
Ahh, and you are sure the equipment is Polydoros Multix Swing-IT?
greetings.
Damisak
This errrors appears in the Touch Panel...?
Check the functions of the 7-segment display on the D500 board in the generato, What number look----
Err010: Power Supply error 0
Description:
• The generator has detected a power supply voltage error.
• +15/-15 Volt low voltages too low or are missing.
• D500 defective.
Err034: Init_Radiation Triggering active 0
Description:
• The radiation release signal was active during initialization.
• Incorrect operation
• W515 cable defective or contact problems
• Console defective
Yamil.
yamil7399@gmail.com
yamil7399
Well, the screen is not touch, it's LCD.
Thank you for the helpI, 'll see what I can do now, I tell you bye
Damisak
No conosco el equipo ni tampoco tengo el manual de servicio, pero por lo que dice el amigo Yamil enfocando la falla todo conduce a la Consola de mando(Ya sea cable data, alimentacion,o la misma consola)..
Yo me enfocaria en Ruido electrico. y en alimentacion..
Una Pregunta el rango de voltage es de 340v a 440v bien.. Pero es de manera automatica?.. si es asi no creo que haya problema.. Pero si es de manera manual no creo que el equipo funcione bien...
Porque no publicas por lo menos la fuente que alimenta el CPU, consola de mando.. Para analizarlo..
Otra cosa Los dos Hablan Espanol, porque hablar Ingles?..
Es mi humilde opinion.. Suerte!!
carlos julio
tesla6
Mi correo es isaac.arriola@hotmail.com
Saludos y de antemano te agradezco
Damisak
yamil7399
el voltaje es automático 380V promedio. el rango es el de la placa característica.
estimados
También creo que el problema es de la consola al generador. revisaré, mediré y haré pruebas, les cuento como va.
saludos y no tengo problema en cual idioma debatamos, take care
Damisak
